Thread: Amplifer help for 2 12" audiobahn AW1208T |
New member Username: Audiobahn1155
Post Number: 2 Registered: Feb-05
| Posted on Monday, February 07, 2005 - 12:49 am: |
what can i use to power these 2 massive subwoofers there 3000 watts a piece max and 1500 rms a piece i would prefer to have 2 amps and they dont even have to be audiobahn please if you know what amp would work tell me |
Bronze Member Username: Sparkey2027
Barnstaple,
England
England
Post Number: 67 Registered: Dec-04
| Posted on Monday, February 07, 2005 - 09:13 am: |
what are the impedances of ur subs |
Bronze Member Username: Opie_har
Somewhere,
One of them
Post Number: 35 Registered: Oct-04
| Posted on Monday, February 07, 2005 - 11:43 pm: |
I have one aw1208t and it is powered by an audiobahn a2200hct, and it is a near perfect match. So two of those amps should do the trick as long as you upgrade your alternator. You can get the amps on ebay for about $350 each, including shipping. They are about 2 feet long and are 1600 watts rms at one ohm stable. |
