Thread: What Amp? |
Bronze Member Username: Joebruce
KY
U.S.A.
Post Number: 48 Registered: May-04
| Posted on Sunday, February 06, 2005 - 07:17 am: |
I need an amp for a set of infinity kappa perfect components 6.5".Which one of these would make them perform the best.Orion hcca 225 didgital referance,orion hcca 225 competition series,orion hcca 225g4,orion hcca 250 didgital ref.,orion hcca 250 cometition series,orion hcca 250g4,ppi art series a300,ppi art series a600,ppi pcx2125? I was leaning towards an orion hcca g4 series but which one the 225g4 or 250g4 the comps are 100watts rms at 4ohms.Any suggestions? |
Gold Member Username: Carguy
Post Number: 1412 Registered: Nov-04
| Posted on Monday, February 07, 2005 - 11:00 am: |
If you can get Orion HCCA 250G4 get it! It is one of the best amp for components and subs. The power will sound very low on paper, but it'll be the loudest 50w rms amp you'll ever listen to. That amp bridged says 800w, but in reality it'll give you more than 1100w rms! Your 2nd chice would be 225G4, then 225 comp series, digital reference then PCX2125. |
