Thread: JBL BP1200.1 Dead on Arrival? |
Bronze Member Username: Booya
Post Number: 12 Registered: 12-2003
| Posted on Thursday, February 12, 2004 - 10:02 pm: |
Ok, this is what i have. Head unit: Alpine 9815. AMP: JBL BP 1200.1, Amp kit: knukonceptz. Subs: 2 JL 12" subs. Just Installed a new JBL BP1200.1 amp. hooked all the power and source leads up. When i turned the key on, the amp came on. However, there was no sound coming out of the subs. I have double checked to make sure the head unit has the "sub level" on and up about midway.(the RCA connections are connected to the RCA "sub woofer" connection on the back of the head unit) The amp turns on with the red LED on for a few seconds, then the green LED turns on and remains constant, but there is absolutly no sound. Looking in the users manual, its telling me if the green LED remains constant, your amp is most likely over heating...dont know how that could be, this was the first time it had ever been turned on. I was wondering if anybody else has had a similar situation with this amp. I have double checked all the wiring connections and everythings looks ok. Also checked to make sure the "gain" was up on amp. Hope thats enough info... |
Silver Member Username: Hydro
Post Number: 109 Registered: 12-2003
| Posted on Friday, February 13, 2004 - 12:22 am: |
Check to make sure your Ground Wire is big Enough at least 4 Gauge and that its mounted to your chassis.Also you might wanna check your amp turn-on wire from the back of your head unit and make sure its connected to the remote wire good.Make sure the remote wire to the amp is hooked up too.Other things could be the amp sees to small of a load which I doubt since it can handle a 1 ohm load,run 10-14 Gauge speaker wire to ur subs. |
Post Number: 13 Registered: 12-2003
| Posted on Friday, February 13, 2004 - 01:00 am: |
I have 4 gauge wire for the power as well as the ground. I'll double check the power connections and ground. For the remote wire, It does turn the unit on when its connected. (the remote wire is very very thin) I disconnected the remote wire from the amp and the amp did not turn on. (as is normal) I was wondering, is it possible for the connection to be good enough to turn the amp on but not fully allow it to operate? as for the speaker wire, im using 12 gauge wire. other than that, thats about all i can think of...I get back to ya and let you know what happens...thanx |
Post Number: 1161 Registered: 12-2003
| Posted on Friday, February 13, 2004 - 02:10 am: |
how are the subs wired, and wired to the amp? what load are you presenting to the amp? the remote line is a 12 volt, low current trigger signal. if the amp gets 12V from it, that's all it needs to tell it to turn on.
Post Number: 14 Registered: 12-2003
| Posted on Friday, February 13, 2004 - 02:40 am: |
These are 2, 12" JL subs in a single box. from the box i have wired them so each sub is connected to its own lead on the amp, that is - to - and + to + ( for both subs) using 12 gauge wire. as far as the ratings of the JL's and how they are wired inside the box im not sure, they are actually my sisters (i just used them to test the amp out, as i do not have my own yet) This I can tell you, those subs are connected to a Phoenix Gold XS 4600, and sound great. I have assumed these subs would be close enough spec wise to test them on the JBL 1200.1, or am i wrong? Also, what if the amp was not getting any sound source?, that is, RCA cables being bad or broken? |
Post Number: 1169 Registered: 12-2003
| Posted on Friday, February 13, 2004 - 08:22 pm: |
If you don't know the impedance and coil config of the subs, I at leastneed the models. JL has subs from 8 Ohms each to 1.5 Ohms each. The JBL amp is 1 Ohm stable.
Post Number: 15 Registered: 12-2003
| Posted on Saturday, February 14, 2004 - 03:41 pm: |
hmm, yea...the only way i can find out the impedance of the JL's would be if i take one of the subs out of the box.(dont see any other indication on the sub itself) I think what ill do is put my amp in place of my other friends amp. He has two 12" Infinity single coil 4 ohm subs. And im pretty sure they'r 600 watts rms a piece. If i just hook my JBL in place of his amp. That should give me a total of 2 ohm load on the amp, wired in parallel...ill see what happens then... |
Post Number: 1187 Registered: 12-2003
| Posted on Saturday, February 14, 2004 - 06:32 pm: |
take the subs out of the box then.
Post Number: 16 Registered: 12-2003
| Posted on Saturday, February 14, 2004 - 07:33 pm: |
OK, This is what I did. I took my Adire Shiva and hooked it up to the amp. putting a 4ohm load on the amp (dual 8ohm coils). it didnt work at first, but at least I was not getting the same symtom from the amp the fist time i hooked it up to the JL subs. the red LED was flashing on and off. So, i double checked the ground connection to the chassis. Sure enough, it was the damn ground connection! and WALLAA... 100% pure quality sound now im just waiting for the sub boxes to be delivered. |
Post Number: 1192 Registered: 12-2003
| Posted on Saturday, February 14, 2004 - 09:26 pm: |
that'd be "voila" sand down the ground point to bare metal, and be sure you're using the same gauge cable for it, and the ground is less than two feet long.
Post Number: 117 Registered: 12-2003
| Posted on Saturday, February 14, 2004 - 11:16 pm: |
Ha Ha Stephen I told you so |
Post Number: 17 Registered: 12-2003
| Posted on Sunday, February 15, 2004 - 12:06 pm: |
Coo, hey glass, just out of curiosity, why should the ground be less than 2 feet? |
