Home > Message Board > Car Audio > Amplifiers > Archive through February 08, 2005 > Can someone tell me if this set up wi...
Author Thread: Can someone tell me if this set up will work
Username: Avp689
3 Kicker Solo-Baric S12L74
Rockford Fosgate Type RF CPCC1
AMP-Kicker KX550.3
Username: Geekbike
Post Number: 33
It would work, but would be a big waste of money. That amp doesn't come close to powering 3 L7s. I'd suggest dropping the amp and one of the subs (you're too restricted on wiring). From the money you planned on spending, switch over to the dual-2ohm versions and find a Orion 2500D. They're some of the best amps out there and it'll give you tons of power. Also, drop the cap and buy a deep-cycle battery and high-output alternator. Caps are only necessary if you're electrical system cannot handle what your using.
Home > Message Board > Car Audio > Amplifiers > Archive through February 08, 2005 > Can someone tell me if this set up wi... [ « Previous ] [ Next » ]
