Home > Message Board > Car Audio > Amplifiers > Archive through February 08, 2005 > Hey Isaac!
Author Thread: Hey Isaac!
Username: James1115
Wilton, Ct
Post Number: 560
I posted this in the subwoofer section by accident. http://www.arcaudio.com/arc-05/amplifiers/xxk_1500.htm check that out I was looking at the input sensativity and it says 250mv-2.8v. My deck is a 4volt out. I know this is at full volume. I emailed arc audio and asked them if they would be compatable and he said If I am worried about it dont be! That isnt exactly making me happy about the whole thing. What do you think?
Username: Carguy
Post Number: 1398
Arc Audio seem to make amps with very low input sensitivity. I think they're using similar technology as Orion HCCA G4 amps. That amp is rated at 5v max, but gain set at minimum will handle 9v. It's one of those hidden features.
Home > Message Board > Car Audio > Amplifiers > Archive through February 08, 2005 > Hey Isaac! [ « Previous ] [ Next » ]
