Thread: What amp would be best |
Bronze Member Username: Luc89
Post Number: 16 Registered: Dec-04
| Posted on Saturday, February 05, 2005 - 03:27 pm: |
What amp would best run with my subs. I have 2 12' audiobahn AW1206T. They are underpowered right now n i need a bigger amp. so what would best run with those subs. Thanks |
Silver Member Username: Xxkmfdmxx
FL
Post Number: 303 Registered: Oct-04
| Posted on Saturday, February 05, 2005 - 04:04 pm: |
I'd go with a ORION 2500D. It isn't cheap though. |
Bronze Member Username: Marley289
Post Number: 77 Registered: Nov-04
| Posted on Saturday, February 05, 2005 - 05:05 pm: |
whats your spending range? |
Post Number: 17 Registered: Dec-04
| Posted on Sunday, February 06, 2005 - 11:37 am: |
spending range is ne were from $200 to $700. But if the amp is worth it, I might be willing to spend more. |
Bronze Member Username: Geekbike
Post Number: 38 Registered: Dec-04
| Posted on Sunday, February 06, 2005 - 02:31 pm: |
You can occasionally find a 2500D refurb on ikesound.com for a great price. |
Bronze Member Username: Sparkey2027
Barnstaple,
England
England
Post Number: 64 Registered: Dec-04
| Posted on Sunday, February 06, 2005 - 02:53 pm: |
id get an audiobahn 2300 hct. it gives out 2400w @ 1 ohm. it ll do the job. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=48597%26item%3D5749707875 &tc=photo |
Post Number: 18 Registered: Dec-04
| Posted on Sunday, February 06, 2005 - 11:48 pm: |
Hey thanks josh walton, I like the audiobahn amp better than the orion cuz i want to do an all audiobahn sound system. That info definitly helped me out. thanks |
