Thread: Isaac! |
| Posted on Friday, February 04, 2005 - 08:58 pm: |
Do YouThink That An Alternator 170 Amps Is Enough For a 700 Watt rms System What About 14oo watt Rms system So When I upgrade To Another 700 Watt Sub. thanks |
Gold Member Username: Carguy
Post Number: 1373 Registered: Nov-04
| Posted on Friday, February 04, 2005 - 09:07 pm: |
A.T., you'll be fine with 170A alternator. To top that off, get 2.5F capacitor and you'll have a very tight bass sound.
| Posted on Friday, February 04, 2005 - 09:27 pm: |
Is There any other online site That sells capacitors for cheap. And Does it matter about what brand i get. |
Post Number: 1379 Registered: Nov-04
| Posted on Friday, February 04, 2005 - 09:34 pm: |
Not really. The cheaper ones don't come with digital readout. Try eBay. I bought mine from 12volt.com I think. It was $50. Remember, it's 1F for every 1000w peak power. |
| Posted on Friday, February 04, 2005 - 11:24 pm: |
Is The Power Acoustik Capacitator good for my set up Http://www.etronics.com/product.asp?stk_code=powpc24fn&store=&catid=309 Its a 2.4 farad Could I still Install It Even Do Im Only Running 700watts Or should I just Wait Till Iget the other 700watt sub. Also How Come It says 24volts DC Does That Mean Icant Run It in my system It's around12-14 volts. Thanks For All Your Help. |
Post Number: 1384 Registered: Nov-04
| Posted on Saturday, February 05, 2005 - 12:46 am: |
Power Acoustik make bad products. Try other brands. The voltage of 24 volts means it'll handle up to that. You can install 2.5F capacitor with 700w rms. The 1000w peak power was just a guideline.
