Home > Message Board > Car Audio > Security Systems > Archive through June 01, 2006 > Install diagram need for clifford sma...
Author Thread: Install diagram need for clifford smartwindows 4 (G4)
Username: S2turbo
hi can anyone help im looking for a install diagram for the clifford smart windows 4 (G4) i am changing the loom in my car and have lost the piece of paper i wrote all the colours and where they go to on the uint is connect to a clifford G5 concept 550 if that is any help
Username: English_boy
WANTAGE, OXON
ENGLAND
Hello Lee
I too need this circuit diagram. I am swapping to another car and havent got the wiring diagram any more. If you have any luck I would be interested.
http://www.drdetailshop.com/deiinstallguides.htm
All Clifford Wiring Diagrams and More !!!!!!
http://www.directechs.com/guides/installguide.asp?
Could you send me a Clifford Wiring Diagram for RSIII model? thx.
NO! buy you could click that link two posts above and find your own!
Damn, dosen't anybody READ anymore?
highwire
clifford is abunch of uppiddy pr***s!can't get a wire diagram out of them for sh**!
highwire
Home > Message Board > Car Audio > Security Systems > Archive through June 01, 2006 > Install diagram need for clifford sma... [ « Previous ] [ Next » ]
