Home > Message Board > Car Audio > Amplifiers > Archive through February 08, 2005 > RCA's - 3 outputs and 2 inputs
Author Thread: RCA's - 3 outputs and 2 inputs
Username: Jwbulger79
Florida
Post Number: 120
I've got an Alpine 9827 HU that has front, rear, and sub RCA outputs. I'm running to a 4 channel amp and powering a set of comps and a 12" sub.
Obviously I run the sub output to the rear channels of the amp, and the front output goes to the front channel input of the amp.
What do i do with the third set of RCA outs - the rear output?
Do I get a y adapter and combine the front and rear RCA out to the front inputs on the amp?
Do I just leave it alone and fade the HU all the way to the front?
thanks ya'll.
Username: James1115
Wilton, Ct
Post Number: 549
leave it alone there is no way you can fade it anyway. Just run the front RCA's back and fade it to the front. What I would do is run them back anyways just tuck them away because in the future if you buy a new amp just for your sub you can just plug it in and change the wires and have the 4-channel for front and rear and amp for subs without having to take out the head unit again.
Home > Message Board > Car Audio > Amplifiers > Archive through February 08, 2005 > RCA's - 3 outputs and 2 inputs [ « Previous ] [ Next » ]
