Thread: Hey guys... one more question!!! |
Bronze Member Username: Chada08
Post Number: 49 Registered: Jan-05
| Posted on Thursday, February 03, 2005 - 08:42 pm: |
Hey wanted to let u guys know i finally got all my stuff put it.. it sounds GREAT! I'm still workin on all the little tweakings and what not, and so far i've realized one thing. My low bass notes (such and the drum hittin) come out real loud, but then the higher bass notes (like the bass guitar) aren't very loud. I was thinkin a few things, such as maby turn the gain down a little and using more bass from the headunit for the 6x9s, or turn my crossover up a little bit on the amp. any suggestions? thanks |
Silver Member Username: Taylor17
Kopperl,
Texas
Post Number: 372 Registered: Jan-05
| Posted on Thursday, February 03, 2005 - 08:59 pm: |
Also, in some head unit's, they have a setting to help that! |
Silver Member Username: James1115
Wilton,
Ct
Post Number: 513 Registered: Dec-04
| Posted on Thursday, February 03, 2005 - 09:09 pm: |
yeah sub control's on the head unit dont know if your has it or not. What is your Low pass x-over set at? |
Post Number: 50 Registered: Jan-05
| Posted on Thursday, February 03, 2005 - 09:53 pm: |
My headunit doesn't, it's just a baisc JVC, nothing special. The crossover i believe is set at around 80, i haven't really had a chance to check it out yet. Just got it installed yesterday and i've been busy lol |
Wilton,
Ct
Post Number: 526 Registered: Dec-04
| Posted on Thursday, February 03, 2005 - 09:56 pm: |
80 is good for subs. I would mess around with it and see what you can do with different settings. |
Gold Member Username: Carguy
Post Number: 1359 Registered: Nov-04
| Posted on Thursday, February 03, 2005 - 11:53 pm: |
"such as maby turn the gain down a little and using more bass from the headunit for the 6x9s", you shouldn't be using the gain/level control that way. It's only to be used to match your HU's preout voltage to your amp's input. Using it incorrectly will damage your amp. As for your bass, if you're missing out on some frequency, it's cause you have set your low pass crossover too low. If you set it around 100hz - 120hz, you should hear the guitar loud. That also means you no longer will get "soft" bass. |
Post Number: 52 Registered: Jan-05
| Posted on Friday, February 04, 2005 - 12:12 am: |
Thanks man... yeah i figured that playin with the crossover was the right way to go, and not the gain lol. What do you mean by "you no longer will get soft bass?" |
Post Number: 1361 Registered: Nov-04
| Posted on Friday, February 04, 2005 - 12:23 am: |
By setting the crossover to 80hz or below, you tend to get "soft" bass from your subs. I had mine around 70hz and it produced nice low bass. By setting it higher, above 100hz, you get higher bass notes mixed in. They tend to overpower the "soft" bass. Experiment with it. |
Post Number: 53 Registered: Jan-05
| Posted on Friday, February 04, 2005 - 12:33 am: |
Ok.... i still don't understand what you mean by the term "soft bass"... just the lower notes? i'll try and play around with it this weekend. |
mr.softie Unregistered guest |
| Posted on Friday, February 04, 2005 - 02:24 am: |
I like soft bass Hey Isaac, do u think one 12" Type R with 300 Watts runnin to it will hit good soft lows? |
Post Number: 1362 Registered: Nov-04
| Posted on Friday, February 04, 2005 - 09:02 am: |
Anything is possible as long as the sub has the right box. 300w rms of pure power is more than enough. A lot of cheap amps will say 300w - 1000w, but that's power mixed with distortion. When a low drum makes a sound, you hear the full beat. With every beat, there's the high bass, mid bass and low bass. Setting your crossover to 80hz or below will zero in on the low bass, giving you a sound that is heard quite a distance away. It's almost like a soft wind sound. It may not be loud in the car, but it travels. Mid and high bass, shakes your trunk and mirrors a bit more including your ear drums. |
Post Number: 54 Registered: Jan-05
| Posted on Friday, February 04, 2005 - 10:03 am: |
Ok.... yeah i guess if i'm not hearin those mid-higher basses hardly at all, i'll mess with the crossover and get back to ya. Is it ok to adjust it while the musis is playin, or sound it be off first? |
Post Number: 1364 Registered: Nov-04
| Posted on Friday, February 04, 2005 - 10:17 am: |
You can adjust it while playing. |
