Home > Message Board > Car Audio > Amplifiers > Archive through February 08, 2005 > Best solution for 2 subs and one 2 ch...
Author Thread: Best solution for 2 subs and one 2 channel amp???
Username: Mez
I have two Orion Xtr series 2 12" subs and a Kenwood KAC-X621 2 channel amp. The subs are dual voice coil 4ohm and the amp has these stats: Maximum Output Power: 1200W
Rated Output Power (14.4V)
150W x 2 at 20-20kHz 0.05%THD (4Ħ)
300W x 2 at 1kHz 0.5%THD (2Ħ)
600W x 1 at Bridged 1kHz 0.5%THD (4Ħ) Rated Output Power (12.0V) 100W x 2 at 20-20kHz 0.05%THD (4Ħ) 200W x 2 at 1kHz 0.5%THD (2Ħ) 400W x 1 at Bridged 1kHz 0.5%THD (4Ħ)
Could you please help me with the best solution to run this equipment or should i purchase another 2 channel amp?
King regards
MeZ
Username: James1115
Wilton, Ct
Post Number: 497
no run them in series at 4ohms and push the 600 x1 @ 4ohms. 300 per sub should be fine for those.
Username: Mez
Thank you so much for the reply and so quick too.... Sounds great thanks once again.
MeZ
Username: Mez
Sydney
Oz
Post Number: 7
Is this diagram correct (Option 2) as to what you have mentioned above???
http://www.crutchfieldadvisor.com/S-Octar4rOwo6/learningcenter/car/subwoofers_wi ring.html?subs=2&impedance=DVC4x2
Username: Carguy
Post Number: 1387
That diagram is for parallel wiring. Your amp will not handle less than 4ohms bridged. If your subs are 4ohms DVC, then wire each sub in parallel as in the diagram but instead of connecting all the negs and pos together, you take one of the pos and connect it to the neg on the 2nd sub. Now you have 4 ohms total.
You should always ignore "max" power ratings. They're meaningless. According to your post, it looks like the amp will be putting out 200w rms to each sub @ 4ohms.
Home > Message Board > Car Audio > Amplifiers > Archive through February 08, 2005 > Best solution for 2 subs and one 2 ch... [ « Previous ] [ Next » ]
