Home > Message Board > Car Audio > Head Units > Archive through March 01, 2005 > Amp turns off when cd is playing
Author Thread: Amp turns off when cd is playing
Username: Djzavala
Whittier, Ca
Post Number: 111
my friend has a panasonic head unit and it works fine with the radio (i can hear it)but when he puts in a cd to play the amp turns off. does anybody know why?
Username: Joebruce
KY
U.S.A.
Post Number: 46
Yes I had the same problem i also have a panasonic hu the remote wire is connected wrong,there are two remote wires,one solid blue and the other is blue with a white stripe.it is connected to the blue/white stripe just connect it to the solid blue one and it should work.
Username: Jeremyc
Kunsan Afb
South Korea
Post Number: 484
yep its conected to the power antenna wire and it nees to be connected to the remote wire.
Home > Message Board > Car Audio > Head Units > Archive through March 01, 2005 > Amp turns off when cd is playing [ « Previous ] [ Next » ]
