Home > Message Board > Car Audio > Amplifiers > Archive through February 04, 2005 > Hifonics BX1500d
Author Thread: Hifonics BX1500d
Username: Nickb920
Post Number: 7
I just hooked up this amp to two !2" Audiobahn Performers and i wired it all up and i am getting no sound. The subs are dual voilc coils 4ohms and i cant figure out if its the wiring or the amp itself. is there a way to tell which is the problem
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 252
tap on the amp with the back end of a screw driver. about four taps should do. ha ha ha. does the amp power light come on? get a short rca cable and plug it into the rca input of the amp and touch the other end with your finger.(might have to turn the gain up) you should hear a hum. if you do then the problem is with your audio source or rca cables. if you dont get anything then double check your wiring and ground connections.
Home > Message Board > Car Audio > Amplifiers > Archive through February 04, 2005 > Hifonics BX1500d [ « Previous ] [ Next » ]
