Thread: Should I get a new alternator? |
| Posted on Wednesday, February 02, 2005 - 09:00 pm: |
I have a 94 Totota Pickup and I just got 2 12in Sony Subwoofers. My friend gave me a cheap 2000watt amplifier. Do I need a new alternator or what what other things can I get? |
| Posted on Wednesday, February 02, 2005 - 10:02 pm: |
what kind of amp is it |
Silver Member Username: Lbeckner
Tulsa,
Ok
Usa
Post Number: 256 Registered: Oct-04
| Posted on Wednesday, February 02, 2005 - 10:18 pm: |
how bigga alternator u have in der right now? |
| Posted on Thursday, February 03, 2005 - 02:15 pm: |
The amp is a cheap amp, its an Audio Mobile MPA-7000 2000watt amp. I dont know how big the alternator is, its the stock one. |
Gold Member Username: Carguy
Post Number: 1346 Registered: Nov-04
| Posted on Thursday, February 03, 2005 - 02:26 pm: |
If it's stock then it'll produce somewhere around 65A - 75A. Since you said it was a cheap amp, it's probably 2000W peak, meaning it can be anywhere between 80W rms - 200W rms. Some manufacturer use a factor of 10! That is pure lie but they actually do it. |
| Posted on Thursday, February 03, 2005 - 05:15 pm: |
Yeah its a cheap amp, but I got it for free. So I don't need a new alternator? Anyways I dont think I am going to install the amp in my truck. But if I did would I need a new alternator with 2 12inch subs and 2000watt amp? |
New member Username: Mikey
Miami,
Fl
Puerto Rico
Post Number: 5 Registered: Dec-04
| Posted on Thursday, February 03, 2005 - 05:39 pm: |
What's the highest alternator amp range I can get for my maxima 95 - 98? Anyone??? |
Silver Member Username: James1115
Wilton,
Ct
Post Number: 489 Registered: Dec-04
| Posted on Thursday, February 03, 2005 - 05:42 pm: |
if it were true 2000 watts yes you would but being a cheapo I doubt it you should be alright. As far as the maxima ? goes you can get whatever you want depends on how much cash you got. |
