Thread: Amp question |
Bronze Member Username: Perrydog
Flint,
Michigan
Post Number: 60 Registered: Jan-05
| Posted on Tuesday, February 01, 2005 - 11:25 pm: |
ok i have 4 12' kenwood kfc 3005's i want them to hit hard and i want to feal it, i mean i want the people next to me to feal it, what amp should i get???? the subs are 175 rms and 700 peak http://www.epinions.com/pr-Car_Speakers_Kenwood_KFC_W3005_Car_Subwoofer_Driver_S ubwoofer_KFC_W3005/display_~full_specs that is all the specs i can get online will someone anyone help me plz!!!
| Posted on Wednesday, February 02, 2005 - 03:49 am: |
feal? |
Flint,
Michigan
Post Number: 61 Registered: Jan-05
| Posted on Wednesday, February 02, 2005 - 09:49 am: |
u know feel it, like makes u shake |
Silver Member Username: James1115
Wilton,
Ct
Post Number: 403 Registered: Dec-04
| Posted on Wednesday, February 02, 2005 - 09:57 am: |
well from the link you posted those subs are 350rms not 175. Look at your info again. If those are the subs you have two options at wiring 1ohm load or a 4ohm load. I would get a JBL 1200.1 or the Orion 1200d and run it at one ohm. The reason I say this is because It is alot more $$$ to find an amp that puts out that kind of power at 4ohms. http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=4+woofers&WoofImp =Single+Voice+Coil+-+4+ohms&image.x=20&image.y=9 That will help you out with wiring. |
New member Username: Petrey
Post Number: 1 Registered: Feb-05
| Posted on Wednesday, February 02, 2005 - 01:18 pm: |
i have 1 15 in. JL AUDIO W6, and i am running it with a 4 channel 400x4 amp from rockford fosgate. is this bad, and if it is, wat could happen to my system??? |
Post Number: 2 Registered: Feb-05
| Posted on Wednesday, February 02, 2005 - 01:21 pm: |
does ne1 know an answer 2 my question
Wilton,
Ct
Post Number: 428 Registered: Dec-04
| Posted on Wednesday, February 02, 2005 - 01:24 pm: |
how do you have it hooked up? I would have to say yes that is bad but I need more info. Ohhh yeah stop stealing threads start your own you will get a better response. |
