Home > Message Board > Car Audio > Amplifiers > Archive through February 04, 2005 > HELP!!! Wiring my amp and subs PLZ!!!...
Author Thread: HELP!!! Wiring my amp and subs PLZ!!!!!!!!
Username: Fatass_tony
I purchased one 12" Pioneer Premier TS-W2000SPL which is 2000w MAX and 750RMS, and i also got a 600w JBL amp JBL BP600.1 which runs an Output 2 Ohms: 600W x 1, how do i correctly set up this system to get MAX clean bass out of it.
Ogh and it also Outputs 1 Ohm: 600W x 1, so apperantly its one ohm stable, any way to use that to get more bass out of it, im guessing not since the amp is 600watt maz, just making sure.
Username: James1115
Wilton, Ct
Post Number: 402
what is the voice coil configuration on your sub?
# Double 4-Layer, Long Voice Coil (2 x 4ohm)
# 4-Slit Glass Imide Voice Coil Bobbin
# 1-Piece Rubber Gasket
# 750 Watts RMS/2000 Peak Power
# Dual Voice Coil Design (2ohm or 8ohm)
# Frequency Response: 18 - 2kHz
# Sensitivity: 89dB (1W/1m)
Username: James1115
Wilton, Ct
Post Number: 427
well you can run it parellel @ 1ohm but you are underpowering them quite a bit. I would get 1 more JBL bp 600.1 and run them both one to each of the subs.
Post Number: 7
You must not have understood me correctly, im only planning to power ONE "12 sub, so i wanted to know if there is a specific efficent way to do it.
Post Number: 9
bump
Username: James1115
Wilton, Ct
Post Number: 440
ok my bad yes run it in parellel at 2ohms should sound good.
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 258
bump
Your info is wrong. The JBL BP600.1 puts out 600W @ 2 ohms, so wire your voice coils in parallel for a 2 ohm load.
Username: James1115
Wilton, Ct
Post Number: 447
thats what I said Anon!
Home > Message Board > Car Audio > Amplifiers > Archive through February 04, 2005 > HELP!!! Wiring my amp and subs PLZ!!!... [ « Previous ] [ Next » ]
