Thread: Head deck distortion at low levels. HELP |
GlenCox Unregistered guest |
| Posted on Tuesday, February 01, 2005 - 10:41 pm: |
Hi, I have a panasonic head deck CQ-C1300W head deck and I can start hearing distortion at just over half way, the volume goes from 0 - 40, and it starts sounding distorted at about 25 - 30. I thought it may just be my speakers but it is distorting on my subs aswell which are running off a seperate amp. Is the head deck the problem? does the signal start getting distorted when turned up just over half way? Any help is appreciated. |
| Posted on Saturday, February 05, 2005 - 11:15 am: |
are u runnin a amp for ur in car speakersers if so check to see where ur rca's are runnin if there runnin with ur amps power wire that could be the cause of the distortion |
| Posted on Sunday, February 06, 2005 - 04:37 am: |
No the speakers are not running off the amp, they are running directly off the head deck. |
Bronze Member Username: Geekbike
Post Number: 36 Registered: Dec-04
| Posted on Sunday, February 06, 2005 - 02:15 pm: |
Are you running the stock speakers? They may not be able to handle what your HU is putting out Check your gains to see if they are properly set. It might be clipping causing the distortion in the subs. |
Bronze Member Username: Yamahaboy
Orland Park,
Illinois
Post Number: 42 Registered: Jul-04
| Posted on Sunday, February 06, 2005 - 10:36 pm: |
he said his subs were distorting too...im having the same proble with my alpine type S's (i think thats the type) but i dont know what its doing it...other people said its the head unit "clipping" but i don't know |
