Home > Message Board > Car Audio > Amplifiers > Archive through February 08, 2005 > Need help
Author Thread: Need help
Username: Mal713nf
OKC, Oklahoma
I don't have very much money to buy an amp. What would be the best amp to buy in the 200-350 dollar range?
Username: Taylor17
Kopperl, Texas
Post Number: 354
What size amp do you need?
Username: Mal713nf
OKC, Oklahoma
Something that will power 2x12's with a peak of 600 watt RMS at 4 ohms
Username: James1115
Wilton, Ct
Post Number: 406
600 rms each or 300 rms each? When you say peak you arnt reading the peak power of the subs are you? what kind of subs are they?
Username: Mal713nf
OKC, Oklahoma
They are Dual 2 1100 watt 12" speakers XINB212 up to 1100 watt peak power (600 RMS) 4 ohm. They come in a box.
Username: James1115
Wilton, Ct
Post Number: 512
hey Joe if you want a really good deallook into JBL 1200.1 or the Kicker 1200(will costa little more) MTX 1200 Orion 1200D, The best deal I have found for a good amp cheap power is the Infinity 1210A you might want to try that one out. Look on ebay and buy new if you can. Just remember to look at users feedback ratings to make sure they are good sellers. 97% or better usually depending on how many sales they have. good luck.
Username: Mal713nf
OKC, Oklahoma
would the Lanzar Vibe 268 be a good buy?
deon g
i got a punch 601s for 250
Username: Carguy
Post Number: 1358
Do not buy Lanzar/Pyramid/Sony/Pyle/ and few other no name brands. They're mostly junk. You will regret it later.
For $200-$300 range, look at PPI/Orion/JBL/MTX amps.
Username: Mal713nf
OKC, Oklahoma
I'm using my brother's sony xplod 760 watt amp right now but it won't turn on. It does have power running to it and none of the fuses are blown. Is it fried?
Home > Message Board > Car Audio > Amplifiers > Archive through February 08, 2005 > Need help [ « Previous ] [ Next » ]
