Thread: I need help wireing |
New member Username: Casper22hptva
Virginia
Post Number: 10 Registered: Jan-05
| Posted on Tuesday, February 01, 2005 - 05:50 pm: |
i need help wireing two amps and a compacitor can some one please help me leave me a message im new to this |
Gold Member Username: Carguy
Post Number: 1335 Registered: Nov-04
| Posted on Thursday, February 03, 2005 - 09:47 am: |
You first need to have power cables wired to wherever the amps are. Then get a power distribution block to connect 2 amps. For capacitor, you need to "charge" it before you can connect. You can do it very easily by using a 12v light bulb. Connect neg to neg on capacitor. Now attach a light bulb on the pos wire on the battery, then the other end of the bulb to the capacitor's pos. When the light goes out, it means the cap is fully charged. Now you can connect it to the amp without causing major spark. Keep the capacitor to the amp as close as possible (wires less than 18"). |
| Posted on Thursday, February 03, 2005 - 04:42 pm: |
i need color code for the wiring harnest so i can run the remote wire back to the amp and i really dont want to cut the harnest off and test one by one (2000 chevy s-10
Silver Member Username: James1115
Wilton,
Ct
Post Number: 486 Registered: Dec-04
| Posted on Thursday, February 03, 2005 - 04:48 pm: |
hold on before you go cutting anything! Do you have a stock head unit? If not it is a blue wire coming off the back of your head unit. If you do have a stock just run a wire from your radio or cigarete lighter fuse in the fuse box back to the amp. |
| Posted on Sunday, February 06, 2005 - 05:02 pm: |
I am wireing in track lighting.I am going to use a middle run outlet for power.I kinda know how but would like hep on how to wire it. |
