Home > Message Board > Car Audio > Amplifiers > Archive through February 04, 2005 > Hifonics zeus z600
Author Thread: Hifonics zeus z600
Username: Davidcphillips
San Diego, CA
United States
I have a problem with my amp getting real hot. Does anyone have any suggestions what I can do.
Username: James1115
Wilton, Ct
Post Number: 376
that amp is a beast. Old huh? What are you running with it? how do you have the gains set 1/4, 1/2, 3/4, or full?
Username: Carguy
Post Number: 1311
You might also want to check the speaker ohms. If you exceed the minimum ohms of the amp, it will start getting really hot.
If they're all okay, then a cpu fan will do the trick. I installed one of them and it kept the amp's temperature to a reasonable level. Before it got as hot as a stove top.
Username: James1115
Wilton, Ct
Post Number: 378
yeah thats what I thought at first as well thats why I was wondering what he was running with it. Godd call on the fan They burn out easily.
Home > Message Board > Car Audio > Amplifiers > Archive through February 04, 2005 > Hifonics zeus z600 [ « Previous ] [ Next » ]
