Thread: WANTED-Orion HCCA 225g4 |
Bronze Member Username: Joebruce
Post Number: 23 Registered: May-04
| Posted on Monday, January 31, 2005 - 10:12 am: |
I was wondering if anyone knows where i could get one of thes amps new/used.I have looked on ebay and cant find any.If anyone has one or 2 of these for sale, i am very interested so please let me no.Or if there are any sites out there that have them.Thanks |
Post Number: 24 Registered: May-04
| Posted on Monday, January 31, 2005 - 10:44 am: |
Ive also heard these amps are VERY under rated,I need 400-500 watts rms x1 at 2ohms.Will this amp give me that or around that? Oh and I found one brand new for $330 shipped BRAND NEW!! Believe it or not. |
Gold Member Username: Carguy
Post Number: 1280 Registered: Nov-04
| Posted on Monday, January 31, 2005 - 11:12 am: |
I have HCCA 250G4, and let me tell you, it is one of the best amp I tested. 225G4 is half the power of 250G4 but it still a very nice amp. You will get much more than 400W rms. Using that amp to power a sub would be a waste cause of what it can do with component speakers. |
Post Number: 25 Registered: May-04
| Posted on Monday, January 31, 2005 - 11:15 am: |
well i was goona get 2 one for my components and one for my sub. Is that a bad idea? |
Post Number: 1282 Registered: Nov-04
| Posted on Monday, January 31, 2005 - 11:20 am: |
No, they'll sound very good. I'm using my amp to push component speakers. I like the Intelli Q control. |
Post Number: 26 Registered: May-04
| Posted on Monday, January 31, 2005 - 11:28 am: |
Or should i get a class d amp for my sub? I was also looking at the zapco ref. 500.1 it puts out 500rms x1 at 2ohms. |
Post Number: 1286 Registered: Nov-04
| Posted on Monday, January 31, 2005 - 11:38 am: |
Unless you're getting Zapco C2K 6 or Reference 750, I'd go with Orion HCCA G4 amp. Trust me you will get 500W rms or more from 225G4 bridged. It's very clean power too. You can't compare class D amps to G4. You won't find too many amps that can out power a sub amp and at the same time power components. Words can't describe what that amp can do, you'll just have to experience one. |
