Home > Message Board > Car Audio > Amplifiers > Archive through February 04, 2005 > Orion 225 HCCA for subs?
Author Thread: Orion 225 HCCA for subs?
Ohm-ish
I read on one of the threads dat the orions are underated..hows this one? im shopping around for an amp to power a sub...dont have the sub yet..tho.
Specs:
25W X 2 @ 4 Ohm
THD : < 0.03%
S/N Ratio : > 110 dB
Output Load : ½ - 16 Ohm
Damping Factor : > 200
Slew Rate : 30 V/mSec
Username: Carguy
Post Number: 1281
HCCA amps are VERY under rated in power. Yes, it says 25W x 2 but hook up any component/sub and you'll see what it can do.
Ohm-ish
But will give out enough juice for one 4ohm Type-R 12"? i dnt have the power rating on the sub. But the amp specs did state dat it was 400Watts max tho.. oh and its used. Waddya think?
Shuld i go with a used 225 HCCA or a new 350.2 Kicker?
Ohm-ish
Oh btw.. im not sure what model the orion amp is.. all i can see from the pics are that they're ORION 225 HCCA..and the words 'Digital reference' underneath the 225 HCCA.
Username: Carguy
Post Number: 1292
Orion HCCA amp will kick kicker's a$$ in performance and power. If you want to use it with a sub, look for Orion HCCA 225G4 model. It has low, high, as well as Intelli Q control for it.
If you have equalizer in you HU, then Digital reference will do fine. It is not 400W max, it's under rated 400w rms.
Home > Message Board > Car Audio > Amplifiers > Archive through February 04, 2005 > Orion 225 HCCA for subs? [ « Previous ] [ Next » ]
