Thread: Whats a good match for REX.X.X |
New member Username: Energyzed
Post Number: 1 Registered: Jan-05
| Posted on Sunday, January 30, 2005 - 09:10 pm: |
15 inch? Dual 4 ohm REX.XX, i've had it for a while and its in a ported box. I had jbl 1200.1 to it (icky) and i need something better. My budget is around ~350 or less. Thank you, I was looking at some of the Hifonics amps. I just dont know! |
Silver Member Username: James1115
Ct
Post Number: 321 Registered: Dec-04
| Posted on Sunday, January 30, 2005 - 09:17 pm: |
the JBL is a better amp then the Hifonics. I would try the orion 1200D see how that works out for you. Or try an older Orion HCCA model amp. Alos many people use that amp with that sub and are very happy with it maybe it is your enclosure. What type of box do you have and how big? |
Post Number: 2 Registered: Jan-05
| Posted on Sunday, January 30, 2005 - 09:40 pm: |
its around 4.5 cubes, box is fine. i just wanted a little more power, and a subsonic filter. I was also looking at the performance teknique ICBM-D 2000 watt amp. Eh. |
Ct
Post Number: 322 Registered: Dec-04
| Posted on Monday, January 31, 2005 - 12:11 am: |
I dont know if you should be running that kind of power to that sub. I know it says 1600rms but that is a thermal rating and it only needs about 1200 to reach full excursion. Especially in a box as big as 4.5cu/ft. I have no use with that performance technik nor havee I heard anything about it so I cant help you very much with that. Maybe Jonathan can help you out. |
Silver Member Username: Solacedagony
New Jersey
US
Post Number: 242 Registered: Oct-04
| Posted on Monday, January 31, 2005 - 12:24 pm: |
These subs take some power to get moving so you probably want an amp capable of 1600W RMS, even if you aren't going to be using the full 1600W all the time. The JBL amp is probably better than either the Hifonics or the Performance Teknique. Those are both relatively cheaper brands. For a subsonic filter, you can get one of those bass blockers, if you need to. I'd say to look into one of those Orion 1200d amps, if you really want to get a new amp. |
Ct
Post Number: 332 Registered: Dec-04
| Posted on Monday, January 31, 2005 - 01:41 pm: |
you know what amp you might want to check out? Try the Infinity 1210 mono amp I believe it is like 1530watts at 2ohms. That should work great for you. If you need that much power. |
Post Number: 3 Registered: Jan-05
| Posted on Monday, January 31, 2005 - 06:48 pm: |
what would be a better decision at running the orion 1200d at 2ohms or the infinity at 2ohms? |
Ct
Post Number: 338 Registered: Dec-04
| Posted on Monday, January 31, 2005 - 06:51 pm: |
I would go with the infinity. But either one will power it just fine but the Infinity has a little more umph, Because it has an additional 300 watts. |
Post Number: 4 Registered: Jan-05
| Posted on Monday, January 31, 2005 - 10:04 pm: |
Yeah i havent heard much on that infinity amp, so didnt know how good it was LOL! |
Ct
Post Number: 352 Registered: Dec-04
| Posted on Monday, January 31, 2005 - 10:14 pm: |
Infinity is made by Harman International Industries, Incorporated. They also make the JBL products as well. They are a good company with reliable products. Now Orion is made by Directed. They now make PPI,Orion, and a few others. In my opinion I would go with the Harmon gear over the Directed but many would prob disagree. Again it comes down to prefference. They are both good companies.
Post Number: 5 Registered: Jan-05
| Posted on Tuesday, February 01, 2005 - 06:47 pm: |
Thanks a bunch, i'll probably buy that if i get no suggestions oh and i already sold the JBL 1200.1 |
Silver Member Username: Hdubb
Farmington,
Nm
Usa
Post Number: 559 Registered: Nov-04
| Posted on Tuesday, February 01, 2005 - 06:50 pm: |
there is eds nine 1 also. its 350 shipped |
Gold Member Username: Jonathan_f
GA
Post Number: 3135 Registered: May-04
| Posted on Tuesday, February 01, 2005 - 07:15 pm: |
Given the choice of those amps, I'd choose the JBL BP1200.1. Excellent amp for the money. Everything I've heard of the newer Infinity and JBL amps has been shaky, the older power series was a better series of amps. How much power you give is totally dependant on the type of enclosure you plan to run, but I'd plan on at least 1000 RMS in most applications, the full 1600 is usually not required. |
Post Number: 7 Registered: Jan-05
| Posted on Tuesday, February 01, 2005 - 09:42 pm: |
i had the JBL 1200.1 for about 2 years, i wanted a new amp. One with a subsonic filter, too. So eh. I've only read 2 reviews on the inifnity and it was rated good, hm. |
Post Number: 8 Registered: Jan-05
| Posted on Friday, February 04, 2005 - 11:01 pm: |
sorry about the double post, but what about this amp? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem%26%26item%3D4513671105& category=80741&sspagename=WD1V |
Post Number: 9 Registered: Jan-05
| Posted on Friday, February 04, 2005 - 11:04 pm: |
ack link not working if not its the CONCEPT CD-2410 |
