Thread: 2 subs,Mono Channel amp |
Bronze Member Username: Jhick8
Post Number: 15 Registered: Jan-05
| Posted on Sunday, January 30, 2005 - 08:00 pm: |
I have 2 Polk/momo 12' subs that I want to hook up to a 1 channel amp. How do I wire them both to the amp? Also, any suggestions on what amp would be good? thanks |
Bronze Member Username: Byrumjr
Post Number: 67 Registered: Jan-05
| Posted on Sunday, January 30, 2005 - 08:29 pm: |
How to wire subs to the amp depends on what the subs coils are single or dual and at what ohms are they. Remember If both subs are going to be hooked up to a mono amp. The watts will be split between both subs. However you hook them you should look for a amp that puts out a RMS around the same as the subs. |
Post Number: 16 Registered: Jan-05
| Posted on Sunday, January 30, 2005 - 09:08 pm: |
They are single voice coil at 4 omhs. They are rated at 400 rms |
Bronze Member Username: Marley289
Post Number: 59 Registered: Nov-04
| Posted on Sunday, January 30, 2005 - 09:09 pm: |
wire them in paralell, here is a pic of how to do it. |
