Thread: 4 gauge wire amperage? |
Bronze Member Username: Mrdark
Post Number: 45 Registered: Dec-04
| Posted on Sunday, January 30, 2005 - 02:13 am: |
I was reading about THE BIG 3, and I did it on my car!! Now I am almost complete, besides the fuse that goes inline the alternator-to-battery wire. I read that the fuse should match the amperage of the wire being used? or should it match the alternator's amperage? And, if it does indeed have to match the wire's amperage, what is the average 4 gauge wire ampitance? Thnks alot. |
Gold Member Username: Carguy
Post Number: 1265 Registered: Nov-04
| Posted on Sunday, January 30, 2005 - 09:57 am: |
The fuse is suppose to match your current load. For example, if you have an amp that's eating up 120A of current, then that is your fuse size. 4 gauge will handle fine up to 135A.
Post Number: 47 Registered: Dec-04
| Posted on Sunday, January 30, 2005 - 07:26 pm: |
ok, so 120 amp fuse. where can i lookfor a 120 amp fuse? i checked aroundalready in a lot of places, and 80A @12v is all i can find? |
Post Number: 1276 Registered: Nov-04
| Posted on Sunday, January 30, 2005 - 08:08 pm: |
Your best place is eBay. Do search on car fuses. I bought mine from there. |
