Home > Message Board > Car Audio > Amplifiers > Archive through January 29, 2005 > What amp is best for a 2000w Pioneer ...
Author Thread: What amp is best for a 2000w Pioneer Premier????
Username: Fatass_tony
Hello i want to get a 2000w pioneer premier and i wanted to know what amp would be good enough to make it thump, here are the specs on sub.
# nterlaced Carbon Fiber / Glass Fiber Reinforced IMPP Cone Woofer
# Wide-Roll, 3-Layer Fiber Woven Radial Surround with Honeycomb Cloth
# Double 4-Layer, Long Voice Coil (2 x 4ohm)
# 4-Slit Glass Imide Voice Coil Bobbin
# Conex Damper with Damper Ring
# Projected Pole Yoke with Vented Pole
# Double Stacked Magnets (110 oz.)
# Thick 7/8" (20mm) Top Plate
# Aluminum Die-Cast One-Piece Rigid Chassis
# Silver Binding Posts
# 1-Piece Rubber Gasket
# 750 Watts RMS/2000 Peak Power
# Dual Voice Coil Design (2ohm or 8ohm)
# Frequency Response: 18 - 2kHz
# Sensitivity: 89dB (1W/1m)
# Recommended Enclosure: 1.5 Cubic Feet
thank you for your input
Username: Rsxs
Orlando, Florida
Just match your average power... 750 W RMS
the lower end of the frequency response (18 Hz) is very nice!
How many speakers are you pushing?
If only one, use a single channel 750 RMS and that will have at least 1500 W Peak Power. That will make it thump.
I am only pushing one sub but i dont know what amps are good, im looking on ebay and there is alot of amps, im considering a kenwood 1000w amp here are the specs, will it bump nice? i dont know anything about ohms and they seem to be important.
POWER RATINGS * - Maximum Output Power: 1000 Watts * - Power Output at 2 Ohms, at 14.4V (100Hz, 0.5% THD): 400 Watts x 1 * - Power Output at 4 Ohms, at 14.4V (20Hz - 200Hz, 0.5% THD): 200 Watts x 1 AUDIO FEATURES * - Class D Operation * - Ground Isolation Circuit * - Quiet Turn-On * - RCA Audio Inputs: Gold-Plated * - RCA Line Outputs: Gold-Plated * - Selectable Infrasonic Filter: Off/15/25Hz, 18dB per Octave * - Speaker Connectors: Gold-Plated, Screw-Type * - Speaker Level Input Terminals: Plug-Type * - Variable Low-Pass Electronic Crossover: 50Hz - 200Hz, 18dB per Octave * - Bass Boost: Off/+12dB (90Hz)
Username: Taylor17
Kopperl, Texas
Post Number: 245
With that sub, you need to find an amp that says 750 or close to it times 1 at 2 ohm's.
Good amp's are the
Mtx 801D
Hifonic's 800D
There are a few other's.
Username: Rsxs
Orlando, Florida
Ohm's is a measurement of impedance or resistance... in this case impedance... all you have to do is match your impedance... ex: 4 ohm speaker needs a 4 ohm output from amp...
use a simgle channel... that amp will work fine for your sub. you can get a more powerful one if you want and still be alright.
if you have 2 sub's (4 ohm), you can then match them in series and have the 2 ohm impedance listed above. otherwise look for an amp for your single sub:
single channel (also called something else.. i forget)
750 rms
1500 Peak Power (or more.. up to your 2000W)
you can use less power (like your kenwood) and still thump. just dont go over the 750W rms
ps: kenwood is my favorite brand... always have been reliable for me. thats what i use in my house. but i use sony in auto... they seem to have the best quality/specs for the price.
good luck
Username: Taylor17
Kopperl, Texas
Post Number: 246
A single channel amp is called a class D
Home > Message Board > Car Audio > Amplifiers > Archive through January 29, 2005 > What amp is best for a 2000w Pioneer ... [ « Previous ] [ Next » ]
