Thread: Installing two amps |
New member Username: Brock5515
Greensboro,
North Carolina
Post Number: 2 Registered: Jan-05
| Posted on Friday, January 28, 2005 - 02:19 pm: |
I have a knwood headunit with a front and rear set of preouts. I just brought a mtx sub and a audiobahn amp for the sub,but I want to add a audiobahn 2channel amp for a set of Infinity 6x9 speakers for my rear. My question is what would be the best way to hook up the two amps to my system. |
Gold Member Username: Carguy
Post Number: 1235 Registered: Nov-04
| Posted on Friday, January 28, 2005 - 02:28 pm: |
You can get a rca splitter and use it for the rear and sub amp. |
Bronze Member Username: Perrydog
Flint,
Michigan
Post Number: 53 Registered: Jan-05
| Posted on Saturday, January 29, 2005 - 09:18 am: |
ok how exactly do u hook up a rca splitter and can u split the ground and power and remote or cant u not????? and if u can were do u buy rca splitters |
Post Number: 1251 Registered: Nov-04
| Posted on Saturday, January 29, 2005 - 10:48 am: |
You can buy rca splitter from Walmart/BestBuy/CircuitCity or any stereo shop. It takes 2 rca jacks and turns it into 4. If one of your amps has "pass thru" rcas then use that. As for power, get a power distribution block. Makes it lot easier to connect multi amps to one power wire. Yes you can share power, ground and remote wire.
