Thread: New PPI Amps?? |
| Posted on Thursday, January 27, 2005 - 11:02 pm: |
How are the new PPi amps? I know the older ones are good but hard to find. Here is the link for the amp I was looking at?http://www.woofersetc.com/product.asp?0=407&1=408&3=3432 |
Gold Member Username: Jonathan_f
GA
Post Number: 3087 Registered: May-04
| Posted on Thursday, January 27, 2005 - 11:07 pm: |
Nothing like they used to be. Outsourcing production overseas, the old ones were hand made in Arizona. You're better off finding a used Art series amp if you go the PPI route. |
| Posted on Thursday, January 27, 2005 - 11:14 pm: |
Well i need an amp for one set of infinity kappa perfect components and issac said to go with a ppi. Wut are some good amps for them? I need 100-150 watts rms. |
Silver Member Username: James1115
Ct
Post Number: 281 Registered: Dec-04
| Posted on Friday, January 28, 2005 - 10:41 am: |
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5739062190&ssPageName=MER C_VI_RSCC_Pr4_PcN__Stores that amp will do you wonders. |
Gold Member Username: Carguy
Post Number: 1227 Registered: Nov-04
| Posted on Friday, January 28, 2005 - 11:06 am: |
You can still find good PPI amps. Look for PCX4125, PCX2125, PCX480, 404.2, 600.2 Art series. I wouldn't touch the new PPI series though. They look ugly compared to Art series and quality isn't what it used to be. You have to remember, new amps will have similar spec or better, but the parts used to make them aren't as durable. Look at Zapco for example. They use high quailty parts, so it costs much more. |
| Posted on Friday, January 28, 2005 - 12:43 pm: |
Hey james that link isnt working for some reason could you give me the item number for it or a description of it? Thanks |
Bronze Member Username: Maniac
Post Number: 12 Registered: Dec-04
| Posted on Friday, January 28, 2005 - 05:30 pm: |
I think PPI Is starting to be like Pyle,Pyramid,and all those other sorry brands. Theyre just worried on how it looks not how it performs. |
Post Number: 1241 Registered: Nov-04
| Posted on Friday, January 28, 2005 - 05:54 pm: |
That may be true, but there's still plenty of old PPI's around to buy. |
GA
Post Number: 3092 Registered: May-04
| Posted on Friday, January 28, 2005 - 05:59 pm: |
I wouldn't say it's Pyle and Pyramid-level kind of bad, more like mid-level such as Rockford Fosgate (another great company that went down in quality). |
Post Number: 1242 Registered: Nov-04
| Posted on Friday, January 28, 2005 - 06:37 pm: |
The good thing so far is that RF and PPI still have plenty of good old amps for people to buy. If you want a real tragedy, look at Orion's HCCA amps. Those are some wicked amps made with quality. I have one and will be getting another before they disappear for good. Even though it's an old amp, it has better features and spec than most amps now. I can't believe a company would stop making a product that good. See what happens when greed takes over? |
GA
Post Number: 3095 Registered: May-04
| Posted on Friday, January 28, 2005 - 10:48 pm: |
"See what happens when greed takes over?" And changes in the market as well. There aren't as many people who are out for super high end sound quality equipment anymore. Now most people just want something that looks good and gets obnoxiously loud. Companies such as Orion (back then I mean), PPI, Zapco, Arc Audio, don't make the money that big mass marketing companies do, so seeing a big wad of cash will big stars to the eyes of the owner of smaller companies(like you said, greed). I wish PPI still did make the Art series, but oh well. I'm thinking about getting a Black art series amp once I start my next project. |
Post Number: 1244 Registered: Nov-04
| Posted on Friday, January 28, 2005 - 11:04 pm: |
Hey Jonathan, you have to listen to Orion HCCA 250G4 amp. It is awesome! I'm comparing it with my home stereo side by side. I can't believe it sounds louder and cleaner than home digital stereo amp. At 4ohms, it's suppose to give 50W rms, but it sounds 2x stronger than 100W rms stereo. The mids and highs are very chrisp. Just makes me wonder why Orion stopped making it. |
GA
Post Number: 3096 Registered: May-04
| Posted on Friday, January 28, 2005 - 11:20 pm: |
Haven't heard the HCCAs, have heard the 1st generation SXs and XTRs, but that was a LONG time ago. |
Post Number: 1247 Registered: Nov-04
| Posted on Friday, January 28, 2005 - 11:30 pm: |
If you ever get a chance to buy Orion HCCA 250G4 amp, do it. It's one of the best I've ever tested! Ignore their power ratings. It says 50W rms x2 @ 4ohms, but I swear, it's louder and pounds harder than most 400W amps. I ordered the last G4 amp today. If you ever buy one and aren't satisfied, I'd gladly take it from you.
