Home > Message Board > Car Audio > Amplifiers > Archive through February 04, 2005 > Issac
Author Thread: Issac
Username: Erik123456
Arlington, Tx
Post Number: 361
Do you have any recommendations for 1 eclipse titanium dual 4 ohm sub preferably a D class so i can get away with a 150 amp alternator
Arlington, Tx
Post Number: 368
or anyone else if they have a suggestion
Username: Carguy
Post Number: 1229
Erik, for best possible sound quality, Class AB is the amp to get for subs and highs.
Check out Zapco, Orion HCCA, PPI's PCX series, Diamond Audio, Xant, US Amps, JL.
For specific models, try PPI PCX2400,PPI pc21400.2, zapco reference 750, Zapco Reference 1100.1, Zapco C2K 6, Orion 2100 HCCA.
If you noticed, non of them are class D amps. However, they will sound much better.
Arlington, Tx
Post Number: 369
thanks bud youre awesome
Arlington, Tx
Post Number: 373
the 750 ref is much cheaper than the 1100
so with a dual 4 ohm sub I would just run the 750 amp bridged and have no problems at all?
Username: Carguy
Post Number: 1275
Zapco Reference 750 will do just fine. You're not only getting an amp that can power mids and highs but subs too. Class D's are useless except on subs.
Reference 750 is 750W bridged at 4ohms. It doesn't say if it supports 2ohms bridged. What you can do is wire the 2 voice coils in series for 8ohms and then use it with the amp bridged. I had the same problem cause I only had 1 18" 4ohms DVC. You'd be surprised how much a clean amp could pound compared to cheap amps with 2x the power.
Just so you know, Reference 750 is a fast amp, great for reproduction of mids and highs.
There is Orion HCCA 2100 amp. It is a beast, rated 1600W rms. Another amp is Orion HCCA 250G4, rated 800W rms.
Since HCCA amp's are very hard to get, I'd go with Reference 750. Great amp.
Arlington, Tx
Post Number: 375
thanks man, will the "fast amp" translate into more responsive bass if used only on the ti or is that only wishful thinking
Username: Carguy
Post Number: 1278
A fast amp WILL produce better bass also, but you'll notice the biggest change with mids and highs.
If SQ is what you're after, then you won't be disappointed at all. This is why it costs more.
You'd think it's a simple process, taking the signal from HU and reproducing it as close to the original as possible. Not many amps can do that.
The best way I can describe it is, hearing sounds vs being able to pick out every instruement in a song.
Arlington, Tx
Post Number: 377
i am repairing (or sending in) an eclipse 33230 will this amp do the same thing for components or is it not really close?
Arlington, Tx
Post Number: 378
but back to what you said in another post another reasoing im considering selling the ti - is that they are so loud its tough for a daily driver
1 alpine type r in a good box with a solid amp is almost more than you could need for just driving
Username: Carguy
Post Number: 1279
Eclipse 33230 sounds like a decent amp but can't tell without specs.
If you're going to sell your sub, then get 2 less powerful subs. That way it'll give you more options with an amp. Unless you want to wake up your whole neighbourhood, 300W rms x 2 is good enough for SQ.
How much is it going to cost you to the amp repaired? Have you thought of taking that money and investing in a good amp like Zapco/Orion HCCA?
Home > Message Board > Car Audio > Amplifiers > Archive through February 04, 2005 > Issac [ « Previous ] [ Next » ]
