Thread: Help with amp and sub |
New member Username: Bootykang
Post Number: 1 Registered: Jan-05
| Posted on Wednesday, January 26, 2005 - 04:45 pm: |
I have a 200 watt 2 channel amp hooked up in my car with some a crapping house speaker. I want to get rid of the house speaker and get an actual car subwoofer.but i dont know whats a good sub and how many watts the sub can have in order for it to work on my amp. Any suggestions |
Bronze Member Username: Marley289
Post Number: 47 Registered: Nov-04
| Posted on Wednesday, January 26, 2005 - 04:50 pm: |
what is the amp model? |
Post Number: 2 Registered: Jan-05
| Posted on Wednesday, January 26, 2005 - 04:53 pm: |
VR3 2.0 |
Post Number: 48 Registered: Nov-04
| Posted on Wednesday, January 26, 2005 - 04:59 pm: |
did you buy it from walmart or am i missing something here? |
Post Number: 4 Registered: Jan-05
| Posted on Wednesday, January 26, 2005 - 05:05 pm: |
yea i bought it from walmart like a cheap b@stard why do they suck or sumathing cuase i dont know nothing baout this stuff |
Post Number: 49 Registered: Nov-04
| Posted on Wednesday, January 26, 2005 - 05:13 pm: |
lol well theyre not great by any means, if you are going to stick with that amp, i would recommend 2 subs, 12" that are 4 ohm single voice coils, and they are rated at 100 - 150 rms each. here is some that i recommend. (remember to buy 2 of them) subs - http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13770 then once you get them, wire them like....
i know your amp is 2 channels but this will probably get you the best results |
Post Number: 5 Registered: Jan-05
| Posted on Wednesday, January 26, 2005 - 05:16 pm: |
alright thanks alot |
