Home > Message Board > Car Audio > Amplifiers > Archive through January 29, 2005 > 4 Channel Amps
Author Thread: 4 Channel Amps
Username: Gball6
Charleston, IL
Post Number: 8
I have 4 12" Audiobahn speakers that are 400 watts a piece. I was told to get a 4 channel amp. I want to get a good amp but I only have like $300 to spend. Any suggestions? if its a little more in price thats okay.
Thanx
Username: Carguy
Post Number: 1206
You don't need 4 channel amp for the subs. Get a class D mono amp that's 1200W rms and is 2 ohms stable. 4 subs wired in parallel and then in series will give you 2ohms total load.
Search eBay for 1000W - 1200W rms mono amp.
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 238
agreed. except you could also get a class d 1 ohm stable amp and wire all the speakers in parallel. same difference.
Username: Carguy
Post Number: 1209
If you connect 4 4ohm DVC subs in parallel, you will not get 1ohm total.
Username: Mrdark
Post Number: 41
ya like .5 or .25
Username: Gball6
Charleston, IL
Post Number: 9
Any suggestions on what type of mono 1200 watt amp would be good?
Username: Carguy
Post Number: 1211
Zapco/Orion/PPI/US Amps/JL/JBL/Audiobahn/MTX all make amps over 1000W rms.
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 245
yes. it would be .5 ohm. i didn't know they were dvc. sorry.
also kicker makes an amp too.
Home > Message Board > Car Audio > Amplifiers > Archive through January 29, 2005 > 4 Channel Amps [ « Previous ] [ Next » ]
