Home > Message Board > Car Audio > Amplifiers > Archive through January 29, 2005 > Boss C3000D ( N E Good?)
Author Thread: Boss C3000D ( N E Good?)
Username: Tonkatoyx2
Hey is this amp any good
heres its stats
http://shop.store.yahoo.com/discave/c3bocldmopoa.html
let me know
thanks and if you can will you point me out to a good sub for it?
thanks
Username: Taylor17
Kopperl, Texas
Post Number: 211
They aren't that good of a brand! Poor quality and not as strong as they put on!
If you want an amp that big, and that minny watt's, look at
Hifonic 1800D
Mtx 1801D
Both are good amp's, and will put out a true 1800 watt's.
As for sub's you want for the amp, I need to know a little more! Like, how much money are we talking about, and how minny subs, what size sub's?
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 239
i rate boss with pyle and such. not good stuff. by the way i thought the biggest amp mtx makes was the 1501d.
Well Im not really wanting anything crazy. just really wanting one sub that will put out pretty good like a 15" or a 18" my spending range is $250ish.
Thanks
Username: Marley289
Post Number: 41
get a 15",they tend to put out a lot of bass. i recommend getting mtx.
this amp
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13290
this 15" sub
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13314
then wire it down to 2 ohms, should sound good
I can spend up to $275 on a sub alone if you can point me out to a better one that would be awsome,
thanks alot!
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 246
then get a mtx 8515 or 9515. awesome subs.
you would also need a bigger amp for these woofers. i recommend the mtx 801d or the 1501d. (this would really be loud)
Username: Marley289
Post Number: 55
yea i have the 311D and that is loud enough for me, i couldnt imagine the 801d or even the 1501d, it would be LOUD
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 250
i have the 1501d and I WANT LOUDER
Home > Message Board > Car Audio > Amplifiers > Archive through January 29, 2005 > Boss C3000D ( N E Good?) [ « Previous ] [ Next » ]
