Home > Message Board > Car Audio > Head Units > Archive through March 01, 2005 > Power but no sound
Author Thread: Power but no sound
AIM: krnschair
installing a jvc headunit into a 95 mustang.
all the wiring was done correctly, do not know what is wrong.
cd player works and reads a cd, but no sound whatsoever comes out of the speakers.
same with the radio, shows it works.
message me please! help!!
Username: Kklagge
Post Number: 43
Does the HU happen to have a setting to turn off the internal amp? (like my Alpine 9831 does). I accidently had mine off when I was testing my system before I hooked up my amp.
chhaya
I have a alpine 9831 how do you turn the internal amp on.
Username: Kklagge
Post Number: 82
If you have the manual it's explained in there...if not I can dig mine up if needed.
Home > Message Board > Car Audio > Head Units > Archive through March 01, 2005 > Power but no sound [ « Previous ] [ Next » ]
