Home > Message Board > Car Audio > Amplifiers > Archive through January 29, 2005 > What do you think
Author Thread: What do you think
triple x subs
what do you guys think about a hifonics 1800.1 mono d class amp hooked to a 15" triple x sub hooked parallel to give a 1ohm load and the amp says it puts out 1800 watts at 1 ohm will that be to much for the sub or do you think that will be a good match thanks for any and all input
triple x subs
just putting this back on top for some input thanks
triple x subs
please i need to know if this will work before i spend my money if it will work ill be ordering it tonight thanks
triple x subs
hello any one want to give there in put
triple x subs
please give an idea [lol]
triple x subs
hello any one gonna help
Username: Hdubb
Farmington, Nm
Usa
Post Number: 480
ya it sould work great. im not sure if the hifonicsput out what they say but if they do then just be easy one the gains my triple x friend. it should sound real good if you can get clean power to it.
Home > Message Board > Car Audio > Amplifiers > Archive through January 29, 2005 > What do you think [ « Previous ] [ Next » ]
