Home > Message Board > Car Audio > Amplifiers > Archive through March 04, 2004 > Need help with settings
Author Thread: Need help with settings
Hey i could use some help.
Im running an Alpine deck cda-7893,with a sony 1000w amp(2003 model i think) and 2 alpine type-r 10inch.
my bass setting on the deck are -4, sun volume is 15,bass frequecny is 80. On the amp all the setting are alittle bit blower the half, my problem is after a while like an hour or so the amp overheats. what should i turn down? amp settings or the deck setting?
Thanks A lot Arek
Ill tell you what the problem is, Arek. The amp is a sony. Nothing against you man, but sony is complete trash. Sony must have hired a bunch of 5th graders for their reseach and development team for their car stereo equipment. Get something like JL audio or kicker or RF. Good luck.
Username: Its_bacon12
Post Number: 140
you need urself a BP600.1 JBL amp, very reliable, awesome amp, retails for about $230....it is a perfect matchup for those type-r's
Arek
Thanks guys, i will pick up a new amp tomorrow and run over the sony with my car that pos, or even better throw it through a window at sony
arek
Post Number: 142
rofl yeah u do that :-)
Home > Message Board > Car Audio > Amplifiers > Archive through March 04, 2004 > Need help with settings [ « Previous ] [ Next » ]
