Thread: 2005 corolla, need help with amp and stock cd |
| Posted on Sunday, January 23, 2005 - 10:34 pm: |
I want to conect an amp and 2 subs to stock radio in corolla 2005. What should I use as the remote power up, i i cant use the antena. and where can i get speaker input if no rca's with out losing power in watts. please help.. |
| Posted on Monday, January 24, 2005 - 06:52 am: |
anybody? |
Bronze Member Username: Jmiller
Post Number: 15 Registered: Nov-04
| Posted on Monday, January 24, 2005 - 10:20 am: |
yes you can use the power antena cable for the remote or you can get and AMP with smart-engage (using speaker level input the AMP goes on when you turn on the radio). As far as connecting the AMP to the stock radio, you have two choices- buy a converter (radio speaker's wire to the converter and connect the AMP to the RCA on the conv) or buy an AMP with speaker level input. |
caraloco Unregistered guest |
| Posted on Monday, January 24, 2005 - 08:21 pm: |
im afraid using the antenna, ill only get amplified if listening to radio. my amp accepts speaker inputs, but will it lower the wattage of the speakers. because it only has 4 speakers.... |
Post Number: 18 Registered: Nov-04
| Posted on Monday, January 24, 2005 - 09:48 pm: |
Using SLI will not lower the wattege of your speakers(as far as I now). What are you going to use the AMP for? For the radio and what else? |
| Posted on Tuesday, January 25, 2005 - 07:31 am: |
i want ot use it maily for my cd player, my stco cd player is a 6 disc changer. What is SLI |
Post Number: 19 Registered: Nov-04
| Posted on Tuesday, January 25, 2005 - 09:25 am: |
SLI= speaker level Input. I guess my question is how would you use your AMP when the radio is not on? |
| Posted on Tuesday, January 25, 2005 - 07:41 pm: |
yeah, thats the biggy i have right now. can i conect the switched o direct voltage to where the remote power up, will it fry it. I can always add another switch, then ill use the amp whenever i want... |
Post Number: 21 Registered: Nov-04
| Posted on Wednesday, January 26, 2005 - 08:27 am: |
I still don't understand what you're trying to do, What other sources of input would you connect to the AMP? What do you mean by "using the AMP whenever you want? If it's not for the radio, what else do you want to use it for? |
| Posted on Thursday, January 27, 2005 - 07:55 am: |
Whenever i want means cd and radio. i am thinkin of creating a bridge between the remote start up and the 12 volt lead wire. I will use a switch on the remote start up wire to turn the amp on or off. Then if i want to listen to music i turnit on, and if not in the mood of amplifying i can turn it off. If i put 12v on the remote start will it fry it. What do you think. How much voltage can it take.... |
Post Number: 24 Registered: Nov-04
| Posted on Thursday, January 27, 2005 - 08:38 am: |
If I understand correctly, you have two radio, one w/o a CD. Or are we talking about a portable CD player? And you want both devices to have access to both the AMP and speakers on demand. If that is the case, I don't know enough to help you out. |
