Thread: Just Got 2 12's |
BlueBallz020 Unregistered guest |
| Posted on Sunday, January 23, 2005 - 09:44 pm: |
I just bought two used 12's. They are 400w rms, 4 ohm dvc. If I wire them in a parallel that will give me 1 ohm right? So now I need am amp. I was thinking since they are used i would give them each 300w. What is a good website to buy off online, and who makes an amp that is stable to do 600w rms x 1 at 1 ohm? |
Bronze Member Username: Rhassler
Post Number: 55 Registered: Dec-04
| Posted on Monday, January 24, 2005 - 06:56 am: |
try www.onlinecarstereo.com or www.sonicelectronix.com the orion 600d is 600w rms x 1 at 1 ohm and is about 280 shipped at onlinecarstereo. theres others too, but i dont know your price range
| Posted on Monday, January 24, 2005 - 01:51 pm: |
Id like to keep it under 300 but more towards 2 if possible. Thank You |
Bronze Member Username: Jlprix91
West,
Michigan
Usa
Post Number: 54 Registered: Oct-04
| Posted on Monday, January 24, 2005 - 04:10 pm: |
directed 750d 600x1 rms @1 ohm you should find it under 300 i found it for 200 but i cant remember where |
| Posted on Monday, January 24, 2005 - 05:21 pm: |
I found it.Does directed make good amps? http://www.cardomain.com/item/DEI45013 |
