Thread: Amp fuse trouble please help |
New member Username: Mdimas
Post Number: 1 Registered: Jan-05
| Posted on Sunday, January 23, 2005 - 08:17 pm: |
Hi i have a 3000 class d amp which is Legacy hooked up to 2-12 inch power acoustic subs in a box.The problem i have is the power fuse keeps blowing.The amp and the speakers are both brand new.Any one have any ideas what may be causing this i am getting so aggrivated. |
New member Username: Adampit
Post Number: 6 Registered: Dec-04
| Posted on Sunday, January 23, 2005 - 08:47 pm: |
I had brigded my ppi-pcx2125 amp to my 2 alpine type r's and every 10 mins i would blow the fuse... i dont know whats wrong and neither did the audio store we both have this problem anyone have any ideas? |
Silver Member Username: Hdubb
Farmington,
Nm
Usa
Post Number: 470 Registered: Nov-04
| Posted on Monday, January 24, 2005 - 12:59 am: |
how big are your guy's fuses they may be to small. |
Bronze Member Username: Byrumjr
Post Number: 37 Registered: Jan-05
| Posted on Monday, January 24, 2005 - 01:19 pm: |
It could be the way you have it hook up. At what ohms are the subs hooked up at. Sound like the amp is trying to push more ohms than it can handle and pulling to much volts and getting to hot causing the amp to pop the fuses. |
Bronze Member Username: Sparkey2027
Barnstaple,
England
England
Post Number: 63 Registered: Dec-04
| Posted on Monday, January 24, 2005 - 02:08 pm: |
you may have a short somewhere. check all your wiring. check the cable sizes. |
