Thread: Amp For Infinity Kappa Perfect 6.1 Components?? |
| Posted on Sunday, January 23, 2005 - 04:54 am: |
Wut amp would work the best with one set of infinity kappa perfect 6.5in. components.They are rms at 97 watts but i was just gonna run an amp with a 100x2 watts rms.Wut are some good amps with that rating? |
| Posted on Sunday, January 23, 2005 - 07:16 am: |
Ive been looking around and came up with these amps. Zapco Reference 2ch 300w,100x2-$379 Zapco iForce 2ch 300w,100x2-$224.99 Hifonics Zeus 2ch 400w,100x2-$189.99 Soundstream Rubicon 2ch 500w,100x2-$199.99 Soundsteam Van Gogh 2ch 400w,100x2-$458.99 Alpine 2ch 600w,110x2-$199.99 Clarion 2ch 400w,100x2-$209.99 Hifonics Nemesis 2ch 400,100x2-$159.00 Pioneer 2ch 760w,125x2-$129.00 JBL 2ch 600w,180x2-$249.99 JBL 2ch 260w,97x2-$129.99 MTX Thunder 2ch 500w,125x2-$249.99 Infinity 2ch,97x2-$145.00 Im still looking but are there any amps that I should mark off my list,which ones are better than others?Any other suggestions?My price range is no more than $300-$400 |
| Posted on Sunday, January 23, 2005 - 08:54 am: |
I personally like the infinity, alpine and the hifonics zeus. these 3 are a great bang for your buck if you're on a tight budget. but since you're willing to spend a little more, i've heard good things about zapco. i'm sure someone could enlighten you more on this. |
| Posted on Tuesday, January 25, 2005 - 03:46 am: |
Also ive herd infinitys love power so should i run them more than 100 watts rms? Maybe run them at like 150 or 200 watts or would that be too much? |
| Posted on Tuesday, January 25, 2005 - 12:09 pm: |
Anyone have any advice or comments i would really appreciate it? |
| Posted on Thursday, January 27, 2005 - 06:46 am: |
Would I be able to run the JL 300/2 its 150x2? Is 150watts too much for the kappa perfects? |
Gold Member Username: Carguy
Post Number: 1216 Registered: Nov-04
| Posted on Thursday, January 27, 2005 - 09:21 am: |
Most bang for your money, go look on eBay for PPI amp. I think for 4 channel, they have PCX-480 model and 2 channel PCX2125. The auction is ending today and so far the bid is $91 for each. I would've bought those 2 amps but since I have Orion HCCA and PPI Art series 600.2 amp, I no longer need amps.
skunkbuds Unregistered guest |
| Posted on Friday, January 28, 2005 - 03:27 pm: |
Ive got a hardly used infinity reference 7540a its 111w rmsx4 @ 4 ohms matched almost prefectly for the 6.5 components. |
| Posted on Friday, January 28, 2005 - 03:44 pm: |
Thanks but i only need a 2 ch amp i know it would still work but its just a waste of 2 ch. Im only running one set of components. |
Post Number: 1238 Registered: Nov-04
| Posted on Friday, January 28, 2005 - 04:37 pm: |
PPI PCX2125. Great amp for your money. |
| Posted on Friday, January 28, 2005 - 04:41 pm: |
I cannot find a ppi pcx2125 if you know where i can get one please let me know.Thanks |
Post Number: 1240 Registered: Nov-04
| Posted on Friday, January 28, 2005 - 05:51 pm: |
If you go to eBay.com and do a search on PPI, you'll see an amp PCX 2125 on sale right now for $150. |
New member Username: Adampit
Post Number: 10 Registered: Dec-04
| Posted on Monday, January 31, 2005 - 11:47 pm: |
i run a pcx-2125 to my 2 type r's and it sounds pretty damn nice |
