Home > Message Board > Car Audio > Amplifiers > Archive through January 22, 2005 > Protect light on and amp wont work
Author Thread: Protect light on and amp wont work
Username: Rancid
Stockton, Ca
Us
Post Number: 15
one of my amps wont work the protect light is on and i checked the fuses and the wires but everything seens to be ok and it still wont work any idea what it might be?
Username: Americanbass
Post Number: 11
check ur ground to see if it came looose that always seems to be the problem when the protect light comes on or if ur speaker wires fell off ur subs and are hitting one another what kind of set up do u have so i can get a better idea of what u are running
Home > Message Board > Car Audio > Amplifiers > Archive through January 22, 2005 > Protect light on and amp wont work [ « Previous ] [ Next » ]
