Thread: Glass Help Out Everyone CHeck Thsi Out Mono Amp COmparison For two alpine type X 12's |
Bronze Member Username: Alpineblaster
Post Number: 41 Registered: Jan-05
| Posted on Saturday, January 22, 2005 - 02:54 am: |
K I have 2 Alpine Type X's and 8 amps that im considering here they are if you guys can give me your opinion that would be great thanks : VR1000D 1000X1 1332 True Watts 1ohm Stable-$425 Phoenix Gold X1200.1 1ohm Stable 1200 Watts RMS $498 JL Audio 1000/1 1000X1 RMS AT 2ohms 2ohm stable $714 US Amps DE-1000 1000X1 1000 watts RMS 1 1/2ohm stable $529 Orion 2500 1 ohm stable 2500 watts RMS $450.00 Kicker 04SX1250.1 1250 Watts RMS 1ohm Stable $674.00 MTX Thunder 1501D 1500X1RMS At 2ohms 2 ohm stable $388.00 Hifonics BX2200D 2200 Watts RMS At 1ohm 1 ohm stable $449.00 Which one do you think i should get would you have any other suggestions around same price???? Need everybodys opinion please! Thanks |
Silver Member Username: Jeremyc
Kunsan Afb South Korea
Post Number: 457 Registered: Jun-04
| Posted on Saturday, January 22, 2005 - 07:53 am: |
Out of that list I would do the JL first, and if that is to much then I would go with the kicker, |
NorthWest,
Michigan
Post Number: 7424 Registered: Dec-03
| Posted on Saturday, January 22, 2005 - 11:32 am: |
personally I'd go with the US Amps, then probably the JL.
Post Number: 42 Registered: Jan-05
| Posted on Saturday, January 22, 2005 - 06:19 pm: |
so you think that US would have most efficiency with power do you think it would be enough for the two subs??? |
Post Number: 43 Registered: Jan-05
| Posted on Saturday, January 22, 2005 - 06:22 pm: |
what about the orion Is that one any good???? |
