Home > Message Board > Car Audio > Amplifiers > Archive through January 22, 2005 > Glasswolf or any one else
Author Thread: Glasswolf or any one else
i want to be herd
ok i talked to hunter yesterday but i cant find that thread so here is what i need to find out i got 2 hifonics 1800.1 mono amps and i want to run them each to there own sub but i want to get the sub with the hardest bass out of these 3 subs
2 12inch triple x's?
2 15inch triple x's?
2 18inch triple x's?
then i need help on witch box to use
ported?
sealed?
sloted?
then i need a battery for the back of my van witch would be best?
and last bet not least witch highs/mids and high/mid anps would be good to run with these subs and amps
ps i got my h/o alt already its 180 amps
thanks for your time and help
http://forum.ecoustics.com/bbs/messages/4/119127.html
That took about 1 second to use the search function
i want to be herd
bringing it back to the top srry
tayl0r 17 please
taylor tell me what you think it looks like you know what you are talking about
Username: Taylor17
Kopperl, Texas
Post Number: 183
Go with the 18's, they will move more air, they have more surface areia. Infinity makes good speaker's and just match up the amp with the rating's on the speaker's.
A sealed box gives you more sq, and require's less space.
A ported box will make your sub a little louder, but needs more aire space.
i want to be herd
thanks for your input taylor 17
Username: Taylor17
Kopperl, Texas
Post Number: 186
No problum, I know what it's like to need help! That is why I try to help as much as I can!
i want to be heard
im sorry i got two threads going
i want to be herd
bringing back to the top for more input
i want to be herd
bump back to the top[lol]
Home > Message Board > Car Audio > Amplifiers > Archive through January 22, 2005 > Glasswolf or any one else [ « Previous ] [ Next » ]
