Thread: Choosing the right amplifier? |
New member Username: Headache
Post Number: 1 Registered: Jan-05
| Posted on Thursday, January 20, 2005 - 11:46 pm: |
Hi, i have 1 12" XTANT X-series 1244 subwoofer with these specs: Specifications X1244 Description 12" Impedance Dual 4 Ohm Power Handling(RMS) 500 Watts Frequency Response 27-150 Hz Sensitivity 87.2dB What kind of amplifier would you recommend to get the best performance out of my subwoofer, i really dont wanna go over $300. |
Gold Member Username: Carguy
Post Number: 1179 Registered: Nov-04
| Posted on Thursday, January 20, 2005 - 11:50 pm: |
You should be able to find lot of amps under $300. Try Orion,PPI,RF,Kicker,JL,JBL,Audiobahn, and MTX. Go to eBay.com and search for amps. |
Post Number: 2 Registered: Jan-05
| Posted on Thursday, January 20, 2005 - 11:54 pm: |
How many channels should i get? |
New member Username: Nwdmax
Post Number: 8 Registered: Dec-04
| Posted on Friday, January 21, 2005 - 03:06 am: |
Mono |
