Thread: Amp Installation Location... Suggestions?!?! |
Bronze Member Username: Chada08
Post Number: 33 Registered: Jan-05
| Posted on Thursday, January 20, 2005 - 11:15 pm: |
I'm gettin my system installed soon, was wondering anyone's opinion on location for the amp - either back of the box, or back of the seat. I've heard it's bad to put it on the box because of all the vibration? Don't know if this is true or not. any help / input would be great. |
Gold Member Username: Carguy
Post Number: 1176 Registered: Nov-04
| Posted on Thursday, January 20, 2005 - 11:40 pm: |
Most people install the amp on the back of the seat in the trunk. You can install the amp on the box if space is limited. It should be your last choice though.
Post Number: 34 Registered: Jan-05
| Posted on Friday, January 21, 2005 - 12:48 am: |
Ok, that's what i was thinkin, thanks. |
