Home > Message Board > Car Audio > Amplifiers > Archive through February 08, 2005 > Dual Orion T300 Amp Installation (Ple...
Author Thread: Dual Orion T300 Amp Installation (Please Help)
Username: Js53402
Racine, WI
Hi, I need some help. I have 2 orion t300 (300watt) amps, 2 12" orion xtreme 500 rms dual voice coil speakers, 2 1 farad voodoo capacitors and a Sony explode deck I would like to install. I have no clue what to do so this is what I was thinking. Running 4 gauge wire from the batt to the back of my van into a distribution block, split into 2 wires to the capacitors then to the amps? Another one of my questions is that there are two hookups on each speaker that are currentl bridged together(there's wires connecting the two) so should seperate them and run one amp to one set of voice coils(one on each speaker) then the other amp the the other set of voice coils(one on each speaker) so both amps right channels are on one speaker and both amps left channels are on the other speaker? Or should I leave them bridged and just run each amp to its own speaker. This is my first semi-proffesional install so any help, suggestions, diagrams or directions would be greatly appreciated!!
Home > Message Board > Car Audio > Amplifiers > Archive through February 08, 2005 > Dual Orion T300 Amp Installation (Ple... [ « Previous ] [ Next » ]
