Thread: Amp for eclipse ti 12" |
Silver Member Username: Erik123456
Arlington,
Tx
Post Number: 342 Registered: Aug-04
| Posted on Wednesday, January 19, 2005 - 09:07 pm: |
anyone have some suggestions - i want an all eclipse system but they dont really have an amp that matches up well with the 12 ti anyone have any more cost effective solutions like a gto 1201.1? |
Silver Member Username: Taylor17
Kopperl,
Texas
Post Number: 145 Registered: Jan-05
| Posted on Wednesday, January 19, 2005 - 09:50 pm: |
Aren't they like 1000 watts, or around there? |
Arlington,
Tx
Post Number: 345 Registered: Aug-04
| Posted on Thursday, January 20, 2005 - 11:37 am: |
750 rms but can take more dual 4 ohm |
Kopperl,
Texas
Post Number: 151 Registered: Jan-05
| Posted on Thursday, January 20, 2005 - 07:41 pm: |
I don't know if you want to spind this much money or not. But I like the 1500 watt amp rockford makes. It is called somthing like Rockford T1501. Look's like a good amp! |
| Posted on Thursday, January 20, 2005 - 08:36 pm: |
i have a friend that had 2 12 Ti with a Jl 500/1 amp and you could hear him from 1 mile away. |
Silver Member Username: Lbeckner
Tulsa,
Ok
Usa
Post Number: 210 Registered: Oct-04
| Posted on Thursday, January 20, 2005 - 08:44 pm: |
a mile huh? wow! |
Tulsa,
Ok
Usa
Post Number: 211 Registered: Oct-04
| Posted on Thursday, January 20, 2005 - 08:45 pm: |
jl/kicker/mtx are all good. how much u wanna spend? |
Arlington,
Tx
Post Number: 347 Registered: Aug-04
| Posted on Thursday, January 20, 2005 - 11:45 pm: |
I just want an amp that will fit the sub well... I was also thinking about the jl 500/1 but I didnt want to underpower the sub basically I want a D class amp that can put out between 750-1100ish amps
| Posted on Thursday, January 20, 2005 - 11:58 pm: |
Ok u could get; JBL gto1201.1 and wire it at 4 ohms to get 787 watts x 1 channel [329 bucks online] or mtx 801D. It all depends or VC configuration. |
Arlington,
Tx
Post Number: 348 Registered: Aug-04
| Posted on Friday, January 21, 2005 - 12:15 am: |
its dual 4 ohm and i just looked and the GTO cant accept an 8v pre out it will shut down so i may not be able to get one of their top 2 head units
New member Username: David_pete
Fenton
United states
Post Number: 1 Registered: Jan-05
| Posted on Friday, January 21, 2005 - 04:35 pm: |
hi i have a legacy blue 1000 watt amp and 2 12 inch dual subs i need to know how to put them into a 97 grand am someone try to help me out |
Gold Member Username: Jonathan_f
GA
Post Number: 3033 Registered: May-04
| Posted on Friday, January 21, 2005 - 05:46 pm: |
Eclipse DA7122 if you can afford it. Works very well with that sub, the Ti loves power and is underrated. |
Kopperl,
Texas
Post Number: 167 Registered: Jan-05
| Posted on Friday, January 21, 2005 - 05:58 pm: |
Sorry just now realised that you only have 1 12. lol I would say that the Rockford is a little big for just 1 12, guess I was thinking a head, thought you had 2 12's. My bad Guess if you git that amp you will have room to add!:-) |
Arlington,
Tx
Post Number: 350 Registered: Aug-04
| Posted on Friday, January 21, 2005 - 10:38 pm: |
thanks jonathan & taylor |
New member Username: Mtate
Post Number: 7 Registered: Dec-04
| Posted on Saturday, January 22, 2005 - 12:47 am: |
the eclispe 34230 works pretty good BUT be VERY CAREFUL the coils on that sub are actually rated at 3.1 i learned the hard way and blew a 1200 watt memphis |
