Home > Message Board > Car Audio > Amplifiers > Archive through January 22, 2005 > Will the PHOENIX GOLD 1200.1 handle 4...
Author Thread: Will the PHOENIX GOLD 1200.1 handle 4 10" l5
Username: Mario3716
McAllen, Texas
U.S.A.
Wanted to find out if this amp the tantrum 1200.1 can handle and pick up 4 10" l5. was thinking of putting them in 2 ohms. should it sound good.
Username: Byrumjr
Post Number: 17
The Tantrum 1200.1 says it’s 1400w x 1 Mono @ 4 & 2 ohm. What type of sub and how many watts rms are they. You say 4 10" l5 , This is confusing.
Username: Themax96se
Post Number: 64
L5 kickers... 450RMS each X 4 = 1800
I think it should be good. Do you plan on buying the amp, or do you have it already? I have a T500.2 for sale to match your stronger Tantrum if you need it.
Username: Subfanatic
Walton, Ky
Usa
Post Number: 78
what are the statistics on that amp your seling...and how much will it cost...im looking for a rela strong one to power 2 or 3 eclipse Ti's...just what are the rating and everything...thanks
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 208
i'm not very happy with my 15" l7's. they are loud but dont sound too good.
Home > Message Board > Car Audio > Amplifiers > Archive through January 22, 2005 > Will the PHOENIX GOLD 1200.1 handle 4... [ « Previous ] [ Next » ]
