Thread: Amp for alpine type r |
Bronze Member Username: Basketballinu05
Post Number: 14 Registered: Dec-04
| Posted on Wednesday, January 19, 2005 - 03:46 pm: |
which amp would you all suggest for 2 12 inch type r's would the hifonics bx1500 or bx1000 be a good amp for them i want to get atleast 400rms to 500rms to each sub since they suggest 500 rms to each sub and im not tryin to spend $500 on an alpine amp thanks |
| Posted on Wednesday, January 19, 2005 - 05:06 pm: |
Actually they are rms at 300.I have 2 12" type r's too hooked up to an MTX 500 watt amp its only puttin out like 180 watts to each sub but it still sounds pretty good,but it could sound better.I would get a JL 500/1 for them if I were you,thats like $450 tho.If you dont want to spend that much then look into MTX,Kicker,or a good brand like that. |
| Posted on Thursday, January 20, 2005 - 12:49 am: |
try a jbl amp. there excellent amps for the price. |
Silver Member Username: Erik123456
Arlington,
Tx
Post Number: 344 Registered: Aug-04
| Posted on Thursday, January 20, 2005 - 11:36 am: |
jl 250/1 |
Bronze Member Username: Themax96se
Post Number: 63 Registered: Jan-05
| Posted on Thursday, January 20, 2005 - 01:17 pm: |
JBL 1200.1 |
| Posted on Thursday, January 20, 2005 - 08:20 pm: |
are they the type r 1221d or the 1241d if they are the 1221d get a jbl600.1 or a infinity reference 610a for like 200 off ebay. you will prob blow the subs if you put 500wrms to each one. |
Post Number: 15 Registered: Dec-04
| Posted on Friday, January 21, 2005 - 04:52 pm: |
they are the 2 ohm version so the 1221d so why does some1 say get a jbl 600.1 then some1 says a 1200.1 |
Post Number: 16 Registered: Dec-04
| Posted on Friday, January 21, 2005 - 04:56 pm: |
what does anyone think about getting a hifonics bx1000 |
New member Username: Rob315
Syracuse,
NY
U.S.
Post Number: 9 Registered: Jan-05
| Posted on Friday, January 21, 2005 - 11:20 pm: |
id still go with JBL...and 500watts to each type r will not blow it. |
