Home > Message Board > Car Audio > Amplifiers > Archive through January 22, 2005 > Please help
Author Thread: Please help
I have a Brutus Hifonics 1500x2 and it just went out all of a sudden listen to music it just turned off all the lights come on and everything and when you try to hook speaker wire to it, it makes alittle clickin type noise whats wrong?
Username: Carguy
Post Number: 1153
You'll need to test and see if the amp's ok. Check all fuses and power wires to the amp first. With the amp and subs hooked up, try touching one of the rca cables on the amp's input terminal. If you hear a humming sound, then it's okay.
Just curious, do you have HO alternator in your car? If the amp shuts down your whole car, then that is a serious problem. You're lucky your car's electrical components aren't dead yet.
Home > Message Board > Car Audio > Amplifiers > Archive through January 22, 2005 > Please help [ « Previous ] [ Next » ]
