Thread: Yo Glass, or someone |
Bronze Member Username: Mrdark
Post Number: 24 Registered: Dec-04
| Posted on Wednesday, January 19, 2005 - 03:50 am: |
I have an amplifier that I overdrew, because I used a 1 ohm load when it only goes stable down to 2 ohms. Now, when I power it on, the woofers get power, but totally out of synch with my music. They sound like machine guns "bump bump bump bump...." really rapidly. I can slow these bursts down or speed them up with the frequency control knob, so I know the amp gets power and the frequency knob and gain knob works...I want to repair it, anyone know what part on the board could have gone bad? Thanks. |
NorthWest,
Michigan
Post Number: 7403 Registered: Dec-03
| Posted on Wednesday, January 19, 2005 - 10:02 am: |
a: bad ground or b: blown amp. most likely b. this is why I told you not to run the amp at 1 ohm.
Post Number: 31 Registered: Dec-04
| Posted on Thursday, January 20, 2005 - 07:06 pm: |
well the amp is fine. turns out, the rca input jacks are loose, thus causing much signal interferance. i just need to find a good way to secure them better, maybe resolder the to the board. |
Post Number: 32 Registered: Dec-04
| Posted on Friday, January 21, 2005 - 01:20 am: |
okay...not out of the woods it seems...the amp works when the engine is off. When at 13.8-14 volts(engine running)the amp exhibits the same behavior, "Bump bump....". Anyone have any idea why the amp works at 12v and not at 13.8v? I know it has something to do with the power regulator in the amp...anyone else? All help is GREATLY appreciated. |
